Buying OBX headers... What else
Hey guys i recently picked up a Maggied 04 v. Car is basically stock other than the blower and cat back exhaust...
As I order this system i would like to know what else im going to need for the system install.
System--->
What is the hardware that im going to need to get? Should I Buy new 02 sensors, 02 extensions, gaskets, ect. ? What hardware am I going to need?
any input helps out a lot thanks
Keenan
System--->
Keenan
I am also located in NV so ill be having to go have an E check but as i have many buddies that have all passed running not cats. So ill most likely be tuning out the rear o2 sensors to throw no codes
You need GM multi-layer steel (MLS) header gaskets. DO NOT try to run the gaskets that come with the OBX. They are LITERALLY paper. They should be sued for even including them because every now and again a novice or bone-head will actually try to install them and wind up with a header leak. MLS gaskets are the shiznit.
I just bought these headers too, but the catted version. It was $704 shipped. How many miles on the car? I have always reused the stock gaskets and bolts, however I'm at near 84k so I am going to buy new GM gaskets and buy new bolts. I'm thinking after that many heat cycles the bolts might break when trying to re-torque. You will probably need rear 02 sensor extensions. You are also going to need to hook it up to the exhaust you have to the mid pipe, which will require cutting and using a 2.5" exhaust clamp, or have a shop weld it up. You're going to have to pay attention to this because the mids from obx are 2.5" outlet and some catbacks are 3" throughout, so you might need a shop to fab that up for you.
I would change the plugs while you are there, do the motor mounts if they don't look aftermarket, get some plug wire covers, and do some DEI titanium exhaust header wrap.
Where in NV are you? I'm in las vegas
Im in Vegas too...Thanks for the heads up..... I do see that the system isnt catted but im not to worried about it as ive talked to quite a few people who have had no problem with the smog check here.
I would like to get to know the car scene around the valley and would have no problem grabbing a beer and talking shop.
Keenan
Get new bolts to connect the headers to the head. I wouldn't reuse the stock gaskets either, get new stock one off rock auto... They are like $8 a piece, cheap insurance. Other than that, soak the bolts in a penetrating oil every night before bed and every day while at work for a few weeks... I did it daily, had a can of WD40 in my car. After it cooled down i would spray all the head bolts. I didn't break a single one when I did my header install... I did, however, break one of the bolts that held the stock cat back to the stock manifold on the passenger side and it almost broke my damn face... Sheared that bastard right in half.
I didn't need extensions for my rear O2 sensors on my stainless works headers.
Oh and one more thing... Get some wire insulators for the plug wires. I got some cheap DEI knockoffs from eBay for like $25 I think, for all 8... Otherwise the headers may melt your plug wires
As far as bolts, I got new ones with the Stainless Works kit that I got and they worked fine. Maybe go to NAPA and get new header bolts. Stock ones would work just fine... But I don't think you want to retorque the old ones... even though the torque spec is only like 11lbs/ft I think... It's cheap to get new ones, cheaper than say, having to spend the time and money to yank one out IF it broke.
Here is the MLS ACDelco gasket... http://www.rockauto.com/catalog/more...386&cc=1432726
They are sold individually but they work excellent. They are stock for our cars but they DO NOT leak.
Keenan
Keenan
I just picked up coated Pacesetters for $273 from Amazon.
I got the offroad connectors.
I got the LSX Stage 8 fasteners.
I got the Eastwood, internal Exhaust coating for the headers.
I got Revshift motor mounts.
I got the 6.0 starter that has the normal connector.
I got good plugs.
I got good wires.
Heat shield for the starter.
Heat shield for the wires.
ACDelco manifold gaskets.
I also got upper and lower balljoints and should have got all springs and shocks, but not decided on what I want to do yet.
If you don't already have new cats, then get those.
O2 sensors if you don't have those....
Revshift Tranny insert......
I think that is about it.
I am doing all of this right now, but I have another vehicle to drive, so I know not all of this is attainable for some people, but I like to take my time.
I got good plugs.
I got good wires.
plastic wire tie that holds the alt. wire melts/breaks alt wire come in contact with the naked header arcs burns a hole. it costs 1g to repair the electrical system after. search "whistler header fail"
That picture is probably the sole reason I got the titanium header wrap. It's not ugly like the fiberglass stuff and you don't have to paint it. Just remember to wear gloves and a long sleeve shirt when you're wrapping them.
OBX headers will require a dent in the primaries to clear the steering shaft. A test fit, mark with a marker, and a handful of solid strikes with a hammer should do the trick.
I was on a budget so I cleaned and reused the stock gaskets and bolts. No problems to report here, but I'm well out of the rust belt.
Get an Amazon account and add the coated headers to your wish list and sign up for email updates.
Check it 3-4 times a week.
In small print there will be a scratch and dent if it is available.
I had to wait 6 months, but it was well worth it.
The box was scratched and dented but the headers were flawless.
I also got the eastwood interior header painted and coated the inside, so I should be good now.
