May Cylinder Head Sale!!
Through the month of May get a set of FFHP Stage 1 Heads for just..........$1245.00!(no core required) plus shipping.
Add $100.00 for 6.0L heads
Heads will include
Hot Tanked and pressure tested
Stage 1 porting
FFHP 2.02 Intake Valves
FFHP 1.57 Exhaust Valves
Lunati LS1 Valve Springs(good to .600 lift)
Titanium Retainers
New Spring Seats
New Hardened Valve Keepers
Viton Valve Seals
Bronze Guides
3 Angle Valve Job
Milled up to .040
Flowed
Assembled (ready to bolt on)
Flow numbers are
Lift Intake Exhaust
.200 153 118
.300 212 166
.400 243 183
.500 281 212
.600 293 221
Heads/Cam and ARP Head bolt package $1860.00 plus shipping.
Other options available, call to discuss you goals and setup.
We will refund $250.00 of the above price if you send your stock heads back to us!
Heads will include
Stage 1 porting
Titanium Retainers
New Spring Seats
Viton Valve Seals
Bronze Guides
3 Angle Valve Job
Milled up to .040
Flowed
Flow numbers are
Lift Intake Exhaust
.200 153 118
.300 212 166
.400 243 183
.500 281 212
.600 293 221
Or do just heads and cam for $1595(custom cam design for your heads and application)
Or do heads/cam and GM bolts and head gaskets for $1860.00
All we ask is a $500.00 deposit to place an order. 2-4 weeks lead time.
Suspended Sponsor Account
Originally Posted by jrp
do cores have to be complete or can they be bare? i have both.
In stock and ready to go in short order we have a set of 5.7L heads CNC'd by T.E.A. and hand finished by us, flow numbers are as follows
lift intake exhaust
.200 158 121
.300 216 171
.400 251 187
.500 289 216
.600 302 226
Same price and parts as above!
All they need is milling and final assembly.
lift intake exhaust
.200 158 121
.300 216 171
.400 251 187
.500 289 216
.600 302 226
sure we can do a set with just the heads and valves everything as above other than springs, retainers and seats for $1100.00 shipped. send us your parts and we will assemble them for you as well.
Originally Posted by distortion_69
Do you offer a double valve spring option?
Thanks,
Josh
Thanks,
Josh
Originally Posted by Ed Blown Vert
How much for 6.0L heads with dual-springs. 9.5 CR?
Or can you do 5.7L at 9.5 CR?
Heads bolts? Gaskets?
Sent you a PM with the details
