Should I be good with a stock fuel pump? Loaded question
I'm assuming the stock replacement should be good after reading and Ed Wright seems to be the god here and I'm thinking he's gonna say I don't need more than the stock pump.
Breakdown:
355 fully forged
LE2 heads
42lb injectors
Auto w/ 4k stall
3.73 gears
Stock fuel lines/rails
Any other info needed to help with the recommendation?
Also I have another question about head gaskets. With the heads I'm trying to figure out which gaskets to go with to get the compression up as I may be doing nitrous. I'm looking for links too if possible where to buy and part numbers of which to get. I'm sure you'll probably need more info which ill have when they get back from the machine shop being checked
Breakdown:
355 fully forged
LE2 heads
42lb injectors
Auto w/ 4k stall
3.73 gears
Stock one should be fine NA. Wouldn't a higher-volume pump be a good cheap insurance policy if running nitrous though?
And I concur with 30s being plenty of injector.
The cam is an LE spec'd cam 236/244 .608/.608 110 LSA. I'll keep the 42lbers just in case I go bigger. What brand and size injectors? Like actually 30lbs or 32,36?
And also what are you N/A guys running for head gaskets to keep the compression up?
And Ed you may not be a god but you are definitely a great mentor on here and I try to keep up with your advice
