Manual Window Conversion ('00 Firebird)
I'm interested in converting my auto windows to manual. I'm not doing it for weight savings. I'm doing it to remove unnecessary electronics that will someday fail on my anyway.
If anyone has any experience, post it up!
I'm going to be doing this swap when I get to my car later this year. Mine originally had manual windows and the previous owner swapped to power ones leaving tiny holes in the door panel. I haven't found much info but this thread should help you out.
https://ls1tech.com/forums/chevrolet...onversion.html
I have a done a manual to auto door conversion PITA lol especially when theirs two different sizes of actuators.... The hand is a PITA to get off a manual door they def werent made to break unlike some other design flaws lol
As for the fastening of your actuator goto Home depot or lowes and get some fender washers and bolts with lock nuts put a washer on the insde and outside if you can I used lock tight to hold them in place on the inside this way when you tighten them down the washer will displace the force on the fiberglass and keep them from cracking UNLIKE RIVETS......DONT USE RIVETS CANT STRESS THIS ENOUGH.....ESPECIALLY IN AUTOMATICS.....be very careful when drilling them out .... and haveing bolts will allow you to easily replace something if you need or to go back to automatic.......the holes which youll use will be different because the actuator for a manual arm is shorter use the larger hole where the handle axel will go as your guide ....remember everything is flipped on the inside so keep that in mind as a helpful aid and the spring is a PITA if you have to hook it on the actuator yourself......I might still have mine laying around I can take a picture of for you as a guide no promises
