ready to get started
Old 08-28-2013, 10:29 PM
ianman87's Avatar
Default ready to get started
Spent the last 6 years in AK doing the jeep thing. Back in eastern NM and picking up an ls1 ss on friday. Will have about 2500 to rebuild the bottom end with. Has ms3 sized cam, 243 worked heads, LT's, yada yada, locked up bottom end. I figure I'm gonna need a rotating assembly and probably an oil pump. Anything I need to look for or anyone have a rotating assembly for sale? Looking to 383 the thing. Names Ian btw
Old 09-04-2013, 12:18 AM
jamesSS's Avatar
All I will say is trust the engine builder. You don't want to have to tear it back out. Depending on how bad your bottom end issue is, you may be better off looking for an already working short block and swapping over your cam and heads.
Quick Reply: ready to get started
