t-56 : f body vs gto
Old 08-30-2013, 01:33 AM
69greyghost's Avatar
Default t-56 : f body vs gto
Guys, I need a t56. I found a gto trans for 1500 bucks, seems kinda steep to me but is it worth the coin? Thats no bellhousing, just trans and shifter, its from an 05 gto ls2 powered with 43k. He promises it works. Is the f body t56 better for a muscle car application, are there any drawbacks to getting a gto t56? Or should I look for a stock f body t56 and get it built from there? Let me know what you guys think. I read that the gto trans has a sloppier feel to it and the t56 is a better trans especially if strengthened.
Old 08-30-2013, 06:48 AM
redbird555's Avatar
Well first off a gto trans is actually a t56. As you can see below the gto has a steeper gear pattern for a little heavier car. The only draw back is the t56 for an fbody has a close ratio gear set whereas the gto has a wide ratio between 2-3 however that wouldnt stop me from getting one. 1500 seems ok to me because thats what i would expect to pay for a good fbody one with a bell and the gto t56's command a premium for their synchro design.
The gto t56 uses a triple cone synchro design in 1-2 and then a double cone for the rest whereas the fbody uses a double for 1-2 and single for the rest. This translates into smoother faster shift for the gto. The sloppy notion for a gto comes from the fact the gto shift sucks, once you put on an aftermarket shifter it become like any other t56.
If you wish to make it into an "fbody t56" in terms of fitment for a car all you need to do is change the shifter and offset lever which is around35 bucks. The gto bellhousing should you find one will work with a gto starter or you can just get an fbody bellhousing.
1st 2.97
2nd 2.07
3rd 1.43
4th 1
5th .84
6th .56
the fbody t56
1st 2.66
2nd 1.78
3rd 1.3
4th 1
5th .74
6th .5
Old 08-30-2013, 06:53 AM
HioSSilver's Avatar
I just bought 2 gto t56's for $50. They need work though. I may be able to make 1 outta the 2.
Old 08-30-2013, 09:06 AM
redbird555's Avatar
damn doug wanna send me one? i'll pay shipping lol and rebuild it
Old 08-30-2013, 11:01 AM
Damn, so they can be had that cheaply, 50 bucks makes me feel 1500 is robbery!
Old 08-30-2013, 11:42 AM
HioSSilver's Avatar
IDK red.....don't know if that works for me....
$1500 for a good one is probably fair 69grey.
Old 08-30-2013, 04:49 PM
jmd
jmd's Avatar
redbird had another recent post I liked re: gear ratios:
https://ls1tech.com/forums/17641643-post4.html
Old 08-30-2013, 05:24 PM
HioSSilver's Avatar
That was a good post......I wish he woulda figured the gto trans with 3.73 gears also.....hint hint
Quick Reply: t-56 : f body vs gto
