About to order parts! 02 SS
Hey everybody! My car Has a lid/cutout right now. About to pull the plug and buy the parts listed. What kinda gains, with a good tune, should I see from all this stuff in the 1/4, and on the street? Im wanting high high 11'a-low low 12's, is that possible? And trying to catch up to my friends new 5.0
Let me know!
Thanks! Heres the stuff:
http://www.ws6project.com/user_stor/catalog/98-99-ls1-pacesetter-1-3-4-long-tube-headers-w-emissions-/
http://www.ws6project.com/user_stor/catalog/82-02-motive-performance-3-73-gear-set-2-series-carrier-/
http://www.ws6project.com/user_stor/catalog/98-02-ls1-tci-4l60e-super-street-fighter-3600-torque-converter/
http://www.ws6project.com/user_stor/catalog/93-02-transgo-4l60e-shift-kit/
http://www.ws6project.com/user_stor/catalog/98-02-ls1-pacesetter-3-y-pipe/
Let me know!
Let me know!
http://www.ws6project.com/user_stor/...-w-emissions-/
http://www.ws6project.com/user_stor/...ries-carrier-/
http://www.ws6project.com/user_stor/...que-converter/
http://www.ws6project.com/user_stor/...60e-shift-kit/
http://www.ws6project.com/user_stor/...tter-3-y-pipe/
Let me know!
Not worried abou squeaking out every .3 hp by getting 17/8 th primaries. Im a cheap college kid lol. How is that torque converter? I can spend $950 for a yank. But will this one just go out on my quick? Or can I buy an upgraded one? Ill spend up to 650 on one even if its not 3600. A 3200 would be fine for my needs. I dont plan in camming it any time soon
if funds are tight save up and do it right the first time. keep in mind you will also need a trans cooler and tune with a converter. TCI doesnt have the best history compaired to FTI, Cricle D, Yank. skip the gears and go with a good 3600 stall converter with cooler, a real dyno/street tune, 1 3/4 headers are fine. if done correctly, and you manage to put this new found power/torque to the ground you should net low 12's. but since i dont see any suspension mods, more often than not you will blow the tires off while your buddy's 5.0 walks past you.
Along with what you have listed there I would also consider:
-NGK TR55 plugs
-Poly motor mounts
-Ported TB
-SLP/FTRA ram air setup
On top of that, you'll need good a tune. And if you want to put the new found power down you'll need some drag radials, especially having that stall. LCA's/Relo's would also be a good idea to help with traction.
With all that low 12's/high 11's shouldn't be a problem in the right air. Pulling a little weight from the car never hurts either, check out the weight reduction thread.
My car in sig did 11.90's with bolt-on's and had 11.70's in it with a few tweaks. Getting a stock internal car into the 11's isn't that hard but most people just don't know what they're doing!
Enjoy the modding and do everything correctly the first time!
-NGK TR55 plugs
-Poly motor mounts
-Ported TB
Then why post at all. It's not even a debate anymore, they have been proven over and over to make more power even with minor bolt-ons. I wish someone would have told me that when I bought my first set 7 years ago. They shouldn't even offer 1 3/4" for these cars IMO. And it's not a dead issue if people are still wasting their time and hard earned money on the inferior 1 3/4" primaries.
I also have my own before and after dyno sheet with double digit gains on 1 7/8".
I can't speak for all brands but ARH and Kooks there is a very minimal difference....$20 - $30. TSP's headers are about $90 between the two, should be pretty close to the 1 3/4" pacesetter price. Which headers were you looking at that were a $500 difference?
Just giving my opinion based on doing headers twice and seeing the gains first hand. If you go further with the car (H/C) that's when the larger primaries will really shine.
