98 TransAm, Huron Speed, 7875, 679rwhp on 12psi
Been working on the car for almost 7 months, through knee and hand surgery. All work except the tune was done by me. Shout out to R.P.M (Garner, NC).
Stock bottom end 2004 LQ4
224r 114LSA
Dual Springs
ARP Head Studs
LS9 Head Gaskets
Huron Speed Truck Kit
Turbonetics 7875 1.15ar
3" electric Cutout
Built 4l60e
Stock 10bolt (Until November)
3.73 Gears
AEM TruBoost
AEM Wideband
Devils Own Meth Kit (On @ 6psi)
80lb Siemens Deka Injectors
BRE7F @ .030
__________________
224r 114LSA
Dual Springs
ARP Head Studs
LS9 Head Gaskets
3" electric Cutout
Built 4l60e
3.73 Gears
AEM TruBoost
AEM Wideband
BRE7F @ .030
__________________
good **** through the auto! ive been waiting to see more numbers from these turbos. im currently putting together a turbo setup that will be done next month using the same huron kit and the 78/75, but with a .96 a/r. are you on stock heads just with springs? im rocking prc stg 2.5's that were just freshened up, tick turbo cam 230/235 115lsa and its M6 so shooting for 700+ on the same boost level and upwards to 800 with it cranked up using e85.
It crept up to 14 for a sec then settled back down to 12, but it only did it on 2 runs. Made abouit 720 when it did though
Im running stock heads with prc springs. I have the same PRC stage 2.5 heads but they were milled to 59cc so I didn't want to use them. Will end up selling them
Convertor is loose, but it stayed pretty steady if I remember it dropped maybe 1psia and went back up. Found 2 exhaust leaks, one at the manifold and one just before my cutout, so that could have been it.
running meth on it and no intercooler? I don't see bumper cut out and looks like the lights are in too.. I wanted to do turbo, but can't get past cutting a hole in the bumper on my Bird..
Im running an intercooler, that's an old pic. Plus I have a Devils Own Meth kit coming on at 6 psi.
This is my bird plate I cut out. Not very good pics but will be posting some after I fix my exhaust leak
ok I LIKE THAT! Wish mine was a later model that had the plate like that. mine is a 98 so not sure if they ever had that option or if the whole is the same where I could get a plate and slot the holes in the cover for it to pop in.
Very cool that is what I would want if I did it for sure. The huge square hole by itself is just awful.
Some pics from today. Literally, shes been sprayed off with a hose once in the last 8 months and still looks sexy. Still haven't fixed the exhaust leak, waiting on gaskets.
