Turbo 408, GT91 no power help!!
Well been at trying to tune the car myself, but Ive been beating on it so much trying to get it to perform. I don't want to keep beating for fear im going to where it out! Tried adding timing, and pulling fuel over and over again. Only thing left is a dyno session, but wanted to post a scan to see if I missed anything. Im not use to this large cam, so Im wanting to know do I need to keep adding timing to make it perform? My combo is as follows. LQ9 408, GT91, 239/247-624@114, 4L80E,3600stall, 3.08 gear 28/10inch slicks, 72lbinject, LS1 intake, 317 Heads, dual springs, hand ported. I have a Vic jr not installed yet. Don't wont to hurt the engine, but I think I have a lot of timing already. It go to 12-14psi, and wont get any more boost than that. It did boost to 18psi at one point. I have HP Tuners PRO 3bar OS. Wideband shows 11.7-11.3 thru a pass. Car weights aprox 4,000 1981TTA.Also have a 2step, hydro boost brakes no problem holding car.
No I got 3spray nozzels of meth going in it, as you can see injectors at 70% at 12psi. Well washer fluid because hard to get meth around here. I will check the temp on the cylinders to see if they are down, I had it do that before cause it burnd the wires going thru the manifolds!
Thanks so MUCH!!! I had the wrong plugs in it, or I put what I read on here would work. AC Delcos, they had got hot and the gaps on all the plugs had opened up to 40 or more! Change the plugs and power is here! Got to retune because I been tuning for weeks to get it right with the wrong plugs! Now got to start over, I had to start with the idle, and now it needs fuel up top! Thanks again Hank Peabody, and all who gave advice!
Ok, is the br7ef/tr6 the only number I need to get them from summit?
So what brand of plug is that? NGK? I wanted to post that the car dropped boost to 9psi, from 12psi, but picked up a half a second. So is 11.65@121mph, shifting at 6,300rpm on track for right power? My car weight over 4,000lbs. Think Im going to need a exhaust dump, my full exhaust may be to restrictive? It go from 5inch to 3inch split to 2manaflow straight thru mufflers, car it really quiet. The AFR command is at 10.98, but the wideband is showing 11.5, injectors are at 60% why is it doing that?
