1967 Chevy C10 383/TH350 for sale also on ebay
Year: 1967
Make: Chevrolet
Model: C/K 10
Price: $22400
Mileage: 108000
Private or Dealer Listing: Private Listing
Location (State): LA
Color: Orange
Transmission: Automatic
Drivetrain: Rear Wheel Drive
idle with the new 383
1967 Chevy C-10 Fresh 383 stroker, rides and drives like a modern truck with some extra go when you push the pedal.
383 built in 2013 with less than 200 miles. Engine dyno proven 450hp457tq. 3.75 stroker Eagle crank and Eagle steel I beam rods, .030 over 10.5-1 compression Speedpro pistons, Hastings rings, Double row timing set, Clevite bearings, fresh decked 200 CC Aluminum heads with stainless 2.02/1.60 valves, roller rockers, Comp Cams 253/253 .525 lift with cam card, Holley AED DP High Output 4 barrel carb (Dominator race style, no horn)with 4 corner idle, aluminum high rise intake, Edelbrock fuel pump, high volume oil pump, MSD Blaster 2, MSD ignition, MSD Pro Billet distributor, MSD plug wires, Autolite 3924 plugs, currently 32 degrees timing.
Aluminum 4 core radiator, twin electric fans. Hedmann headers, new dual exhaust, dual Flowmasters.
3:73 gears in a posi 12 bolt rearend, Turbo 350 transmission, B&M HoleShot 3000 converter, B&M Pro Ratchet shifter, transmission cooler
Fresh rebuild on steering box, new power steering pump, Optima Yellow Top battery.
New power brake booster, new disc front brakes, new drum rear brakes. 2" lowering front spindles, new front and rear springs. New front and rear Sensa-Trac shocks. New rollup Revolution Tonno bed cover, fresh POR black paint in bed.
15" American Racing wheels. 31" rear tires and skinnies up front. Lots of tread.
Bright LED headlights, fog lights in front bumper, rear LED tail lights.
New dash pad, new glove box, cloth seats, power driver seat, new carpet, new foil Jute keeps heat out, new matching door panels, new door sill plates. Sony CD player, 2-6" round Rockford Fosgates in doors, plus 2 in the dash.
email at pasbonsimon@gmail.com for the fastest response. asking $22,400
