HELP! reverse lockout
Old 09-02-2013, 12:48 PM
Silver_Bullet_Z28's Avatar
Default HELP! reverse lockout
I just got done installing my new torque arm bushing and as I drive the car down the street the speedometer is not working and when I try to put it in 5th gear it grinds horribly and it won't even let me go near 6th gear. I did move around the reverse lockouts wire to get it out of the way when I was installing the new bushing but I put it back how it was.I don't know if that had anything to do with it but I'm freaking out. Any help or advice you can give me on my situation would be greatly appreciated. Thanks -alex
Old 09-02-2013, 04:39 PM
1slowbusa's Avatar
Calm down and check for pinched wires. If all you did was replace the ta bushing then it can't be something crazy. Jack the car up and inspect everything.
also, are you saying that the car didn't grind in 5th and not go into 6th before placing a simple bushing and now it does? Doesn't make sense to me. Maybe try to change your master clutch fluid.
Quick Reply: HELP! reverse lockout
