Holley EFi tuners in Texas?
We have and tune with Holley, BS3, SCT, HP Tuners, & EFI Live. Depending on the setup we prefer to put the setup on a load bearing dyno we have in Bryan then go to track if needed. Not every setup requires going to the track.
I dont know about running stock gauges with the holley system, havent seen in person with stock gauges but that doesnt mean you cant do it.
Al the info I have seen says not to try and piggyback the gauges with the Holley system, I would hate to burn up the ECU trying to save a few bucks on gauges. The Holley gauges are pretty sweet and you can configure them to any output you want so is not like you are limited to one gauge when you purchase them.
You can control 2 cooling fans based off coolant temp. As for A/C control, that continues to be through the factory switch's. There is a momentary IAC bump that can be configured for A/C equipped vehicles.
Would of it been really that hard to ask for Holley to make it plug and play like a factory system but with better parameters?
Are there any that do A/C control capability. I know FAST has it in its XFI 2.0
I like the Holley system very much and what it can do but when I spend this kind of money on an ECU I want my cake and eat it too.
Sorry for the hijack OP. I'll go create my own thread.
