231/237 owners come in!
Old 05-02-2004, 10:09 PM
five0killr's Avatar
Default 231/237 owners come in!
where do you guys shift your six speed with a 231/237, because i havnt really wound it out yet, im wondering how far to take it
Old 05-02-2004, 10:13 PM
abate1224's Avatar
it drops off around 6300 rpms. i got 435rwhp out of the same heads and cam pkg with a conservative nitrous tune. 450 is deffinately not out of reach.
Old 05-02-2004, 10:25 PM
Mike98WS6's Avatar
I shifted at 6,500 for the first time with it yesterday and it was still pulling hard. I have my limiter set at 6,800.
Old 05-02-2004, 10:48 PM
LS1TECH Sponsor
foff667's Avatar
definitly get it tuned before you run it out...but the cam peaks @ 6300-6500 so shifting at 6800-7000 isnt out of the question just depends on how big your ***** are i guess fwiw my shift points will be set at like 6600 in my auto.
Old 05-03-2004, 09:36 AM
goinbroke's Avatar
Shift mine at 6600 rpm and it still pulls past that.
Old 05-03-2004, 09:38 AM
zwentbyyou's Avatar
Mike at Rapid put my limiter at 7k and I have the light set for 6800. It pulls all the way to 7 strong as hell.
Old 05-03-2004, 09:47 AM
Byter's Avatar
I have a couple of questions for you 231/237 guys.
1. Would I get enough out of this cam with 3.42 rear end? Another way to ask the question is, are you getting a lot of low-end torque?
2. How are you guys with 59cc heads doing with detonation. This chamber volume indicates 11:1 or more compression ratio.
3. Also, why are some of you using the 5.3 heads instead of the 5.7.
Thanks,
Tony
Old 05-03-2004, 10:49 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Here's my dyno graph. Thing pulls hard up to 6900.
Old 05-03-2004, 10:53 AM
LS1TECH Sponsor
foff667's Avatar
Thanks,
Tony
3.73's and up should be recommended as this cam is not a tq monster by any means especially down low. Im running 5.7's but only for the price...the 5.3's will give you a few extra ponies because of the added compression.
lata
Bill
Old 05-03-2004, 11:16 AM
Byter's Avatar
lata
Bill
Thanks Bill. The reason I asked about the gears is because your sig says you're running 2.73's. Are you? If so, are you disappointed in the cam?
Old 05-03-2004, 11:27 AM
LS1TECH Sponsor
foff667's Avatar
if i had a bigger stall I'd probably be better off...and gears would definitly help too...i had to dyno in 2nd because of them lol fwiw i had good mph #'s at the track but the car leaves pretty soft...id really recommend a 4400+ stall vert for an auto.
Old 05-03-2004, 01:40 PM
Charles Cyrus's Avatar
Shift@6500, Limiter set at 6800. Dropped 2 tenths in the 1/8 and picked up 2 mph!
Old 05-03-2004, 01:46 PM
Special K '01 WS6's Avatar
you can run on the 3.42's but gears are highly recommended it's the next thing I do.. (rearend) ...
I shift at 6600 limiter at 6800
Old 05-03-2004, 08:01 PM
Savageite's Avatar
I had my shift light at 6,400.
Old 05-03-2004, 08:17 PM
Mike98WS6's Avatar
I would recommend either 3.73's or 4.10's with this cam. My car pulls hard with the 4.10's from a roll.
Old 05-04-2004, 12:49 AM
greekss's Avatar
SouthFL.02.SS...... y do u only have 390 rwhp ??? with LT's i woudl expect this cam to make ALOT morr power.
Old 05-04-2004, 03:19 AM
silverZ98's Avatar
i have the 231/237 cam and love pulls hard all the way to 6800,
4:10 gears really make this cam pull like a mother broke pione
now im running the stock 3.42s dont fill like it pulls has harder but it still
pulls. i think it might be faster on street cause i can keep the tires from spinning so
dang much lol.
Eddie
Old 05-04-2004, 08:00 AM
!LS1 11 Second Club
Moser 9" rear end robs 10-15hp. I used to have 400 even.
I'll take 390 with a 9" over 400 thru a 10 bolt any day. Most others here would also.
Old 05-05-2004, 12:04 AM
abate1224's Avatar
amen to that! even with less hp you should have a better et.
