How much oil are you down when "LOW OIL" light comes on?
Old 05-02-2004, 10:25 PM
maddboost's Avatar
Default How much oil are you down when "LOW OIL" light comes on?
How much oil are you down in quarts when "LOW OIL" light comes on?
Old 05-02-2004, 10:27 PM
silverbullet00's Avatar
someone correct me if I'm wrong but I believe its 2 quarts
Old 05-03-2004, 03:21 AM
STF veteran / 10 second club
x phantom x's Avatar
Right around 2 quarts.
Old 05-03-2004, 06:55 AM
Buckmaster's Avatar
WOW....2 quarts? I was told, at least for the C5, that it is down 1 quart when the warning comes on..................damn, that is dangerous to run it like that before the warning appears............................
Old 05-03-2004, 11:04 AM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
I had the low oil light come on once. I took 1.5 quarts to bring the oil level up to the bottom of the operating range on the dipstick. Then I added some more to take the level to the top of the operating range.
Old 05-03-2004, 12:18 PM
BIGBOS's Avatar
Its never good when that light comes on, start watching the oil pressure work its way down......
Old 05-03-2004, 12:20 PM
Humm, I am not positive about the C5 ... it could definately be different. In the F-bods you will need right around 2 quarts to get it back up to full from where the low oil light comes on. I would assume the vette is similar, but may not be.
Old 05-03-2004, 07:15 PM
chetyg's Avatar
what do you mean by start watching oil pressure work its way down?
Quick Reply: How much oil are you down when "LOW OIL" light comes on?
