97 lt1 problem
Old 09-03-2013, 08:30 AM
Crazyace85's Avatar
Default 97 lt1 problem
Ran the car about a month ago and when I shut it off it wouldn't crank back up. Would turn over but no spark from coil. Just got around to trying it again today and it fired right up. Haven't changed out any parts. All my dash lights are on though. Brake, asr off, abs inop. Any ideas. Running it now. Gonna see if it will restart after it warms up.
Old 09-03-2013, 08:41 AM
shbox's Avatar
Those dash lights are often in tandem with low voltage. Check and tighten all your battery cables and grounds (especially the ground on the RH shock tower).
Old 09-03-2013, 08:54 AM
Crazyace85's Avatar
Ok will do
Turned it off and back on and lights are off.
Old 09-04-2013, 10:15 AM
Shanle929's Avatar
I had a very similar problem and had to change my fuel pump.
Quick Reply: 97 lt1 problem
