T56 reverse lockout wiring with E67 ECM?
Old 09-03-2013, 09:10 PM
samckitt's Avatar
Default T56 reverse lockout wiring with E67 ECM?
Can anyone tell me the wire colors & the two pins where they connect in the E67 PCM? I think I have found one of them, it is in the J3 connector, but not sure.
Thansk
Old 09-03-2013, 09:40 PM
aknovaman's Avatar
Why don't you connect it up the easy way? Just connect it to the brake light switch so you just have to lightly press the brake pedal and then shift it into gear.
No sense or advantage in making it any more complex than that.
Old 09-04-2013, 06:48 AM
samckitt's Avatar
I guess because I have gone into reverse without having foot on the brake. Prefer having the ECM control it.
Quick Reply: T56 reverse lockout wiring with E67 ECM?
