gen 1 hr in non vented lt1?
Old 09-03-2013, 09:23 PM
94blackz's Avatar
Default gen 1 hr in non vented lt1?
Right or wrong? Ive been reading my @** off all night and have come to the conclusion that the 87-98 hr cams will work in a 93-94 lt1. If so the gm part number 19244485 ( same cam as old gm847 spec wise) is a correct fit. Am i wrong and if so why?
Old 09-03-2013, 10:11 PM
duh
duh's Avatar
It'll fit just fine. Just make sure you tap the dowel in a bit donut doesn't hit anything and you'll be fine. Biggest issue is the timing chain since that drives the 93/94 opti.
Old 09-03-2013, 10:44 PM
94blackz's Avatar
The dowl length is only diff tho correct? Same diameter and location to work with lt1 timing set?
Old 09-04-2013, 06:43 AM
duh
duh's Avatar
Correct. Any Hyd Roller designed for 87+ SBC's will work.
Old 09-04-2013, 07:17 AM
94blackz's Avatar
Thank you.
Old 09-04-2013, 08:47 AM
draggin97s10's Avatar
I was going to tell you last night the dowel will have to be adjusted a bit...
Old 09-04-2013, 01:43 PM
94blackz's Avatar
You never txt me back lol. Did you get your tranny?
Old 09-04-2013, 03:21 PM
No I didn't. But I am interested in the stall Billy has and possibly your gears for the future pill
Old 09-04-2013, 04:21 PM
94blackz's Avatar
Ten four. No problem. When i do my cam swap you in? Ill supply the beer if you supply the tune. :-)
Old 09-06-2013, 11:52 AM
In for the swap
Quick Reply: gen 1 hr in non vented lt1?
