LMR Reaper ZR1 makes 811rwhp on E85!
Old 09-04-2013, 03:04 PM
Closed ex-Sponsor Account
Late Model Racecraft's Avatar
Default LMR Reaper ZR1 makes 811rwhp on E85!
Just finished this Reaper Package ZR1 with a Flex Fuel conversion and needless to say the results speak for themselves! We tuned the car first on 93 octane and it ended up making 737rwhp and then we added E85 to the tank, made necessary tuning adjustments and it made 811rwhp!! A gain of over 70rwhp!
Old 09-04-2013, 06:03 PM
SPRAYED 01's Avatar
Freaking awesome
Old 09-04-2013, 06:08 PM
Blackpanther99's Avatar
Sounds deadly.
Old 09-04-2013, 06:20 PM
psycho1's Avatar
That's nice and bad ***
Old 09-04-2013, 06:27 PM
burbalanche's Avatar
Thats nasty!
Old 09-04-2013, 09:26 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm guessing you had plenty of room with the injectors and fuel system to be able to handle the extra volume needed with e85. Very badass, sadly, there's no e85 around me or I'd switch over.
Old 09-04-2013, 11:05 PM
Detoxx03's Avatar
I would run it if it was available everywhere in my area so for now I'll stick to 93/meth with the occasional splash of unleaded race gas.
Old 09-05-2013, 08:04 AM
chuntington101's Avatar
Is the Flex Fuel conversion seamless and can it handle different % of E85 in the tank?
Old 09-05-2013, 09:15 AM
Yes, during these pulls the computer was showing 63% ethanol content.
Old 09-05-2013, 11:01 AM
venom ws7's Avatar
What size injectors? Great numbers on that boost level I wish we had E85 around here...
Funny how many people said the car lost some Torque
Old 09-05-2013, 11:04 AM
ZO6ER's Avatar
Nice, what's the setup?
Old 09-05-2013, 11:05 AM
2muchboostNY's Avatar
I apologize for my lack of knowledge but engine management does that beast of a Vette use for flex fuel management? I have been trying to do as much research as I can on how to setup a functioning flex fuel setup for my new 5.3 build. I was previously going to use a ProEfi 128 unit to handle that aspect with my 2J setup but havent found too much information regarding the capabilities for these cars....again completely new to these platforms. My concern is that once I leave my area and go on some longer road trips E85 isnt available everywhere and it would be great to just go to a gas station and fill up on Oct. if E85 isnt available and have no worries.
Congrats...killer results and thanks in advance.
Old 09-05-2013, 01:36 PM
Could you just throw a can of meth in the fuel tank with say 93 octane and run? Intresting idea!
Dose it onl detect methanol or will it pick up true octane of the fuel? Would guess it would have to do some in cylinder monitoring to understand that. Proably with some mean knock sensors that are perfectly tuned. Yeah it's not going to detect that is it?
Old 09-05-2013, 03:14 PM
I cant even begin to try and explain how it worked from a technical sense since I have almost 0 technical knowledge on how the ProEfi works. I cant tell you that it detects both E85 (alcohol content) and uses fuel blending tables to adjust the tune as needed. I may even be using improper lingo in trying to explain but you get the idea. So someone could go fill on E85, drive lets say 200 miles, pull up to a gas station, fill up the rest of the tank with 93 octane, and be on their merry way. The tune will adjust for the content and not allow the setup to be pushed into the danger zone. It will adjust the important aspects of the tune to make sure you dont get into any trouble.
Copied from the ProEfi website...sorry for the partial thread jack, still very interested on how this was accomplished in your setup OP:
Flex Fuel (ability to run any mixture of E85 with the ECU making on the fly adjustments to boost, spark, and fueling based on Ethanol content).
Old 09-06-2013, 07:40 AM
125# injectors and yeah, the reason the peak number is lower is because on the 811hp pull we didnt have anyone sitting in the back and it spun the tires on the dyno.
C6ZR1 1 7/8 American Racing Stainless Steel Headers
C6Z American Racing X-pipe with high flow cats
02 Extensions
NGK Spark Plugs(Iridium)
MSD 8.5m spark plug wires
Custom Heat Exchanger
Heat Exchanger water pump with connector
C6 ZR1 High Flow Supercharger Air Intake Snout
C6 ZR1 LS9 2.60 11 Rib 10 Bolt Pulley
ZR1 Corvette High Flow Air Intake Kit
100 mm Diameter Idler Pulley Kit
C6 ZR1 CORVETTE OVERDRIVE HARMONIC BALANCER 2009-2011
160 degree thermostat
LS3 Comp Cam Kit, Comp custom grind cam shaft, comp Double valve spring kit good for .675 lift, Titanium Retainers(custom for ZR1), Spring Seats, Valve seals, and comp chromoly pushrods
Water pump gaskets, Oil pump inlet tube, front cover, crankshaft front seal
LS9 Crank Bolt
LMR custom CNC'd LS9 cylinder heads
Katech Head Stud Kit
MLS Head Gaskets
125# injectors
LMR custom Flex fuel conversion
Spec Twin Disk Clutch
LMR custom dyno tuning
We are using the stock PCM to control this car. HP Tuners is now adding support for all the E40/E38/E67 operating systems to control this. Just have to add a sensor, wire it in, and enable it in the computer.
Old 09-06-2013, 08:47 AM
ZO6ER's Avatar
Nice, what are the IATs difference after the mods? Just curious, this seems to be a hard combo to beat.
Old 09-06-2013, 09:32 AM
@Late Model....much appreciated good sir. Seriously bad *** results on that Vette.
Old 09-06-2013, 10:34 AM
HRHohio's Avatar
Stock pistons/rods? Stock bottom end?
Nice numbers!
Old 09-06-2013, 10:58 AM
Nice numbers!
Bottom end is completely stock
Old 09-11-2013, 08:53 AM
topgun542's Avatar
Thats Odd.... Weird How You Used The SAME Thing But Called It Your Own....
http://forums.corvetteforum.com/c6-t...o-your-c6.html
Quick Reply: LMR Reaper ZR1 makes 811rwhp on E85!
