need recommendations for a drag application lsx 443ci carbed no power adders
Hello there I would like to know your recommendations for the best ls7 style heads solid roller . I have lsx engine built by texas speed and performance its a 443 ci with a 14.:1 . The ls7hheads im using were modified by mti long time back to work with solid roller camshaft . The cam's maxium lift is 670 at intake and exhaust . Im looking forward to change the heads to a better flowing heads which can also with stand a higher lift cams . Im looking for your best recommendations and it is carbed and no power adders at all and the category im in is a foot brake category and the transmission im using isa rosslor th-400 stage 5 trans with a 7k stole speed torque converter ultimate concept thank you and if u need any more info just ask .
Most would recommend talking to Martin at Tick performance
https://ls1tech.com/forums/member.php?u=220340
