changing rims to 18's
Old 09-05-2013, 03:20 PM
chevy94c's Avatar
Default changing rims to 18's
I am thinking of going to 245/40/18 and 275/35/18. Will my speedometer need to be corrected?
Old 09-05-2013, 03:37 PM
DemonicZ's Avatar
245/50/16 OD- 25.65"
245/35/18 OD-24.75"
275/35/18 OD-25.58"
Only thing that will really be affected will be your front wheel speed
245/50/16 speed @ 100 KPH=62.14 mph
245/35/18 speed @ 100 KPH=59.97 mph
275/35/18 speed @ 100 KPH=61.97 mph
245/35/18 speed variance is -3.61% too slow
275/35/18 speed variance is -0.26% too slow
I always use 1010tires.com for a tire size calculator. I always use stock wheel size 245/50/16 or 275/40/17 because that is what the speedo is calibrated for then you can select up to 4 different tire sizes and compare all aspects of the tires side by side.
oh and the answer to your question is no you won't have to re-calibrate your speedo.
Old 09-06-2013, 05:46 PM
chevy94c's Avatar
Thanks for you help
Quick Reply: changing rims to 18's
