1969 Camaro LS7 swap questions
Alright I have a 69 camaro and I have a LS7 longblock out of a 2009 ZO6 for the car, I plan to run a T56 and convert the dry sump system. The biggest question I have is wiring.
I want to pick up a OEM GM harness (new) along with the computer and throttle pedal assembly to run the drive by wire. I don't see why this wouldn't work, but I just wanted some opinions/options on wether or not that would work or should I run an aftermarket system?
The only upgrades that will be done at this point will be headers and fuel delivery, the motor already has a QM550 cam, ported and milled heads, FAST 102mm intake.
