What all do I need to replace an LQ4 cam with a stock cam from an LS9?
Old 09-05-2013, 07:07 PM
rp0029's Avatar
Default What all do I need to replace an LQ4 cam with a stock cam from an LS9?
From what I understand, I need a 2005 LS2 front cover.
I also need a 2005 1x cam sprocket?
Will this work?
I also need a 2005 LS2 chain damper, anyone have a part number?
As well as an extension harness, which I can make.
I am putting a zl1 supercharger on my car and I want to use all GM parts.
Is there anything else I need, and will this work?
Old 09-05-2013, 08:19 PM
AKAFRED's Avatar
isn't the 2005 three bolt and the ls9 one bolt?
you may be better to get custom cam made with similar specs
Old 09-05-2013, 10:36 PM
rp0029's Avatar
Actually not interested in a non-GM cam. I meant to post this in forced induction, but it ended up here. Sorry bout that. If a mod could delete this one I'm reposting it in the Forced induction section.
Quick Reply: What all do I need to replace an LQ4 cam with a stock cam from an LS9?
