Misfire at start-up
Old 09-05-2013, 08:16 PM
Asim's Avatar
Default Misfire at start-up
Hey Guys,
Have a 92 Camaro with an LSx-T56. Ran really good....for the first week after I bought it. Now I have a misfire at start-up. Goes away after 3/4 minutes. Interestingly, not just when cold. I can drive it around for a bit with no problem. Turn it off and start it again and it will miss again for a bit until smoothing out.
Just starts dumping fuel.
OBD1 port so I haven't figure out how to scan it yet.
Any thoughts?
Thx
Old 09-05-2013, 09:01 PM
LS1Tech Sponsor
BP Automotive's Avatar
It should have a OBD II port somewhere. Sometimes it will be mounted on the passenger side, just depends on the harness and where whoever installed the harness decided to mount the port.
Do you know who made the harness?
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 09-05-2013, 10:26 PM
Asim's Avatar
You are correct. Tucked up around the computer.
Thank you Sir.
Asim
Old 09-05-2013, 10:35 PM
LS1Tech Sponsor
Your Welcome, Good Luck!
__________________
1-888-467-4491
Quick Reply: Misfire at start-up
