What all do I need to replace an LQ4 cam with a stock cam from an LS9?
From what I understand, I need a 2005 LS2 front cover.
I also need a 2005 1x cam sprocket?
Will this work?
I also need a 2005 LS2 chain damper, anyone have a part number?
As well as an extension harness, which I can make.
I am putting a zl1 supercharger on my car and I want to use all GM parts.
Is there anything else I need, and will this work?
Will this work?
Sounds about right excluding sensor and can. the timing chain dampener numbers are 12588670 Timing Chain Damper, Black, LS2, 1.762 Bolt Center
88958607 Timing Chain Damper, Tan, LS1/6, 2.187 Bolt Center
Depending on the year of your block will determine which dampener. I believe 05+ take the black one.
