706 heads with boost
Old 09-06-2013, 09:55 AM
Turboswede's Avatar
Default 706 heads with boost
I found out that my lm7 got 706 heads, from what I have read they are ****. Would it be worth to change cam, push rods and valve springs and boost with this heads in a "junkyard build" or try to find some other heads?
Old 09-06-2013, 11:37 AM
a-low's Avatar
Im using those heads on my 5,3 build. Had them rebuilt and had a 3 angle valve job a
nd tooley springs installed. should matter too much on a boosted
application.
Old 09-06-2013, 11:52 AM
87silverbullet's Avatar
You'll be fine for a JY build. leave them on there.
Old 09-06-2013, 11:57 AM
Ferocity02's Avatar
The issue with these heads is that are prone to cracking and leaking coolant, it's a Castech casting flaw. This is not an issue on all 706 heads, just some.
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
Old 09-06-2013, 12:01 PM
Again....its a junkyard build.....boost the **** out of them til they crack.
Old 09-06-2013, 01:21 PM
Turboswede's Avatar
Thanks for the help, Im remove the valve covers and searcing for castech logo after work
Old 09-06-2013, 07:08 PM
Turboswede's Avatar
Woho its castech
Old 09-07-2013, 10:02 AM
Ferocity02's Avatar
Check for the clean areas to see if they have perhaps been leaking. I'd run them if there's no signs of leaking.
Quick Reply: 706 heads with boost
