5th gen newbie here
on the cruise push the button the little indicator lights up then hit set when you get to the speed you want...
the fogs push in on the headlight switch that should turn them on
I believe aac or oracle sells a patch harness kit with the non rs headlight switch so that the fogs can be turned on at anytime. best thing to do with those is get the led lamps the have for those so they match the hid lamps. oh yea get them rear taillight rings body colored. the chrome makes them look bad.
