416 ci + 125rwhp what plug and gap?
Old 09-07-2013, 06:22 PM
randomnine7's Avatar
Default 416 ci + 125rwhp what plug and gap?
Will be spraying my 416 ls3/l92 motor .
It makes about 500rwhp to the wheels on motor and will be running a small nos kit with .57/.33 jets (125rwhp estimate)
What plug ( specific part number please )
And plug gap ?
Car runs on 91oct been 10.5 @128 first time out
Will be re tunning for the bottle and running 100oct
Suggestions on plug and gap thanks !
Old 09-07-2013, 09:38 PM
Anyone ?
Old 09-08-2013, 12:33 AM
HCI2000SS's Avatar
NGK BR7EF gapped at .030-.035 should work well
Old 09-08-2013, 04:18 PM
When would a Ngk 8 be put in ?
Old 09-08-2013, 05:15 PM
HCI2000SS's Avatar
I think you are a good candidate for either to be honest. I mentioned the 7's simply because you are a nitrous car, and that means you won't be under constant pressure like a blower or turbo setup
Old 09-08-2013, 07:09 PM
7s sound good anyone else any input ?
Old 09-09-2013, 07:27 AM
Brennen's01SS's Avatar
I'm running a similar setup with a 416 also execpt it's 11.2 comp. I was advised by nitrous outlet and others to run a BR7. I will gap around .032 to start. Gonna spray up to 150 but am starting small
Old 09-09-2013, 11:15 AM
03EBZ06's Avatar
7s sounds good w/125hp. I use 9s on 200 shot DP.
Old 09-09-2013, 11:26 AM
Sounds good ! Br7s it is !
Anyone knw what kind of et I should be able to knock off the 1/4 ?
Old 09-09-2013, 11:54 PM
Moderator
LIL SS's Avatar
What plug do you run now? How does the strap look after a fresh set of plugs and shutting it off at the finish?
I have a 13-1 418ci and need an 8 on motor alone.
Old 09-10-2013, 06:46 AM
Pretty sure the plug now is a tr6 .
Motor is about 10.1 compression . Never really check the plugs while on motor . Car a is a daily driver and don't race it too often .
Old 09-10-2013, 07:04 AM
Lil ss what size shot were u on with ur times ? I'm assuming ur 6.301 pass is about a 9.8-9.9 and u ran out of gear right ?
Old 09-10-2013, 09:35 AM
Moderator
LIL SS's Avatar
Go read your current plug after a pass. If you don't know if the current plug is right for the motor, you won't know if one step cooler will be ok on the bottle. You might need a 7 for motor and a 8 for the bottle.
The time in my sig was with a 57n jet spraying at the 60' and lifting soon after the 1/8. You are correct, I was out of gear.
Old 09-10-2013, 02:48 PM
Will I still need to read plugs even after I get a dyno tune with the nitrous ?
Old 09-10-2013, 02:52 PM
HCI2000SS's Avatar
I would check them periodically even after your tune
Old 09-10-2013, 02:56 PM
Hole point of reading the plugs is to find out if ur running rich , lean , or hot right ?
If I get a tune were the Afr is monitored and safe plugs don't have to be pulled and checked every run right ?
Old 09-10-2013, 04:08 PM
brandon@nitrousoutlet's Avatar
A little peace of mind goes a long way. Check the plugs periodically.
Old 09-10-2013, 04:39 PM
How often would u suggest as often as I go to the track ?
As often as regular maintanence , every couple thousand miles ?
Old 09-10-2013, 06:02 PM
87silverbullet's Avatar
In my book this is a no-no. Tune the nitrous at the track, not on a dyno. Dyno is not going to load the drivetrain like the weight of the car is.
Old 09-10-2013, 07:01 PM
Well then the tune will be pointless and I would be better off running track passes to get it dialed in ?
Quick Reply: 416 ci + 125rwhp what plug and gap?
