What injectors and fuel pump 800 rwhp?
Old 09-08-2013, 03:59 AM
Jwilliams04's Avatar
Default What injectors and fuel pump 800 rwhp?
I have a 402 LS2 built motor thats NA. I made a little over 500 rwhp on the dyno and decided to put a turbo setup on her. I'm planning on only running 10-15 lbs ( 10 mostly ). I currently have twin 255 walbro in tanks, 46lbs Fast Injectors. What do I need to step my injectors up to and are my twin pumps enough to hand my goal? For fuel I'm thinking 110 race fuel and only run meth its its the last option to keep temps down. Thanks for the input.
Old 09-08-2013, 08:25 AM
FICINJECTORS's Avatar
I think the pumps will be enough, you need our 1000cc injectors. They are a drop in!
Old 09-08-2013, 06:16 PM
What do you have that will fit my needs and work with LS2 setup. Thanks for the info
Quick Reply: What injectors and fuel pump 800 rwhp?
