Anyone try the holley hi ram with a single dominator on top?
http://www.holley.com/300-118.asp
wondering how this would work? modifying the blank top to fit a single dominator. not worried about hood clearance.
will be building a different car this winter drag strip only.thinking about using my 370 ci flattop short block and adding a 10-12cc dome piston to it (roughly 13-13.5:1 compression. with my existing ported ls3 heads with the hi ram on top single dominator and fogger direct port. a nitrous grind cam shaft to match this intake as well. currently have victor jr (ls3) with 4150 carb.
what are your thoughts? cant justify 1400$ for mast intake
