sending units for ls swap
Installing ls 2 in a 67 Camaro need help on sending unit locations for oil and temp for my autometer gauges. keeping stock sending units in place for wiring harness. Any info on parts would be great.
You can install the temp in the plug in the side at the back of the passenger head with an adapter. The oil can be hooked up in the stock location the pcm doesn't care about oil pressure or some have drilled in the oild filter housing for easier access. they sale adapter fittings for the locations I mentioned
