lt1 on motor and on nitrous dyno sheets
Old 09-10-2013, 07:29 PM
unioncarpenter84's Avatar
Default lt1 on motor and on nitrous dyno sheets
the blue is all motor
the red is a 100 shot with 1000psi
the teal color is 100 shot with 900 psi
the air fuel red is all motor
the blue is 900 psi
the teal is 1000psi
Old 09-10-2013, 07:33 PM
its on a pcm4less tune with 4 degrees out on motor also for nitrous
Old 09-10-2013, 08:02 PM
air fuel is everywhere
Old 09-12-2013, 04:57 PM
here are the plugs
what do u guys think
Old 09-13-2013, 10:05 AM
Nitro Dave's Nitrous Outlet's Avatar
Plugs are extremely fat!
What does your set up consist of?
Old 09-13-2013, 11:12 AM
brandon@nitrousoutlet's Avatar
Is that a fresh plug or has it been driven on?
Old 09-13-2013, 03:18 PM
Lt1 350 bored to a 355
Heads ported and polished (flows: intake 278, exhaust 197)
CC Cam 230/242, .510 lift,113 lobe separation
Comp Cams Pro Magnum 1.6 roller rockers w/7/16" studs
Comp Cams 987 Dual Valve Springs
SI Silverline Series Valves,(2.00" intake and 1.57 Exhaust)
Eagle H beem connecting rods
JE Forged Nitrous Pistons
Crane Hardened Push Rods
Ported Intake Runners to match Heads
K&N Cold Air Induction
Relocated Air Intake Temp Sensor
Hooker Headers Long tubes.
Borla 3" exhaust
Accell Super Coil
FMS 30lbs. Injectors
PI VIG 3500 Stall Converter
Old 09-13-2013, 03:19 PM
Its been driving on probably 100 mile
Old 09-13-2013, 03:25 PM
It needs to be a fresh plug.
Old 09-13-2013, 08:03 PM
TravisMcGill2000's Avatar
For your mods you are at least 50rwhp off. You need to lean it out and get to the track. Trap speed be the best way to see the hp in a stalled auto.
Old 09-14-2013, 09:52 AM
i wouldn't say 50 cuz the car runs good now on the street just a lil rich id say prob 10-15 hp
Old 09-16-2013, 12:46 AM
BSmiff's Avatar
I think with h/c you should be at least 350 hp to the wheels boss man. On motor.
EDIT: I was looking at the wrong number. 337 is about right with that cam.
Old 09-16-2013, 03:30 PM
ya with the cam on a great tune prob gain 10 hp that's all id see is my guess
Quick Reply: lt1 on motor and on nitrous dyno sheets
