5V fuel pressure sensor
http://aeroforcetech.com/products_sensors_oil.html
I have it connected to my aeroforce guage.... with a wire run off it to my HPT connector. When I have HPT connected, the gauge is unplugged as they both use the OBD port.
I don't have my laptop with me and could post the exact pid later, but using the information here, it was very simple to figure out and works perfectly.
http://www.hptuners.com/forum/showth...t-to-EIO-input
I want to hook it up so that it logs without the need to wire it directly to the interface just like my AFR gauge. According to a thread on HPT AEM and Autometer has a sensor (part # ?) and the PID is (V*25)-12.5.
http://www.hptuners.com/forum/showth...essure+logging
I have the Fuel pressure sensor and wideband permanently connect to the hpt wire. It is in my glovebox and when I want to log I just pull it out and plug it into the HPT cable.
My wideband is hooked directly to the PCM. I log throught the EGR - pin 55. No need for that wire. I found a tutorial on how to hook the fuel pressure sensor to the EGR signal wire here on LS1tech. I only wonder if two sensors can be hook up to the same wire. In the link look at post two.
https://ls1tech.com/forums/pcm-diagn...-wideband.html
you could use the fuel tank pressure circuit to feed the pcm and do the same as the egr setup. You will need to use all 3 wires because which ever pressure sender you use will require a 5 volt reference and ground to function. The tank pressure is only used for the evap diagnostic so just set the codes to no mil light.
