C5 turbo kits
C5 turbo kits
Anyone have any experience or recommend a good turbo kit for a C5???? I had a PTK and was disappointed. I had several issues with it. I'm looking at TTi and Lingenfelter kits. I'm looking to make 800ish at the wheels
whats the issue with the ptk? we just did one (well found a used new kit) in my buddies car with agp zeta 3.2 turbo's on it and the thing is flat out retarded lol.
had a few fitment and cooling issues but so far it's pretty damn impressive
What was issue with PTK setup?
I have an original kit on my car, works like a champ. Can't figure out why it's designed to brake driveline parts though?
Weird.
The PTK kit isn't for everyone. If you want 800-2000hp, ptk is for you. It requires relocation of coolant tank, and windshield washer fluid reservoir. Also, lots of heat shielding, as it gets toasty without ventilation
If your looking for a great kit, that is simple, and pretty much invisible, TTiX is the way to go for a high end, classy 600rwhp-1200rwhp setup.
Weird.
I had issues with fit on alot of it. The alt was junk and the bracket they sent me was junk also. Not sure how many belts I've thrown. No provision to relocate the ABS and it generated a ton of underhood heat with a vented hood. It made tons of power and retarded torque though when it was on the road which was never very long. And I did break alot of parts. It probably didn't help that I had a bunch of shops that did half-assed work and took my money.......
LS1Tech Sponsor
Wish you lived closer bro.
Sounds like typical PTK issues at first..once bugs are worked out, which takes a bit,..it's a beautiful thing.
Ultimately, that kit,..takes a passionate technician working on it....someone that either knows the system well, has the patience for it...etc. Again, wish you lived closer.
^^This.
The 5th shop that I took the car to (still there) told me that they could fix all the issues with it in about a month. That was 11 months ago. They then said that they could not make it work. I was better off putting g a blower on it..... That's after I got a bill for around 7k for supposedly fixing other "things" that the previous shops left me with. This coming from a shop that builds alot of street cars and a 6 sec 200+ MPH ZO6. They contact me about 1 time for every 6 times i try to call them. Each time I talk to a different person and each time the bill increases. Needless to say, I'm far more than a little frustrated with everything..... So I sold the kit for hardly nothing and I'm looking at doing something else.
LS1Tech Sponsor
V-Series Tech is not a shop, but a dude who worked at a GM dealership and has a passion for all things LS powered, with C5/C6 being his preferred platform.
Since he drives a C5, and works on several for other locals, he knows them in and out. He ran into each and every possible issue you may have seen, plus all the ones you would have runinto in the future, but he managed to over come all of them, rather simply.
if it would have cost him $1000s to make it right, it would have been scrapped day one
its a shame others can;t see things the same way....
I wish that I could find someone with even a little passion for building cars around here. All anyone seems to have a passion for is taking your money. They can bolt on a set of headers or a cai and that's about it. All kinds big promises and no results. And no communication at all.
Does anyone have experience with 417 Motorsports's TT setup? I'm looking at either going that route, or going TTiX. I've read a ton of reviews on the TTiX, but hardly anything on 417 Motorsports's TT.
I"ve been working on my friends setup for about 2 months ironing it out now. everything is wrapped now, has a vented cf hood, and had to heat shield the bottom of the hood. Working on a new radiator shroud and some ducting due to the car running pretty hot on the road. just messing around at 8psi and 10 degrees timing with a 10.5:1 afr the car is already an animal.
truth right there
Will do just gotta get an ok from my buddy first. And no front plate its op3n with some mesh. Doing some ductwork through the bumper support and a new shroud to block in the rad. With the vented hood he has I think air is just passing upbover the rad and not through it. Its laid backbquite a bit.
LS1Tech Sponsor
A pair of NACA ducts are mounted right in front of the turbos, and he also added a pair of extractor vents toward the windshield, look around, there are quite a few pics of the car on this forum (maybe even in his sig?)
I haven't done ANY frame rail mods YET....but, next time the front bumper comes off,..which takes a few minutes, I am gonna probably cut out the big rectangular frame rail and size it down to some round bar for better cooling, and better airflow. Even though my coolant temps and IAT's are awesome.
Big front mount...still allows airflow...
Then, I cut out the support(blue bar) and moved it six inches towards the front of the car.....this raked the top of the radiator back, ....which allows my turbos to sit as is. The car is procharged in that pic but, same concept.
v-series did some rather extensive hood mods to get a decent amount of airflow and heat extraction.
Word.
he NACA ducts I originally thought up just to feed the turbos directly with some fresh air. I am SURE that helps in getting rid of stale air sitting/hovering so,..it has cooling properties as well I believe. The NEW extractors, I have recently added,...I do not know for sure how well it helps as I have not had the car out long enough with it to test. Soon though... anywho, stock hood, modified.
187degrees stock radiator. No frame mods other then front cradle.
nice pics blocked at work, but will check on laptop at work.
and yeah we were going to do some 4" holes through the bumper (5 total) one to each turbo with ducting, the the others for the radiator. Adding a shroud over the rad. HE has a nice cf vented hood on the car already (we cut out the cowl block off already) 5 vents in the front, and 4 over each wastegate. Been getting better, but the rad just isn't getting airflow as of right now.
word.
Nice, looks familiar.
