Need help with trouble codes
Old 09-11-2013, 05:00 PM
Cajun ELESS-ONE's Avatar
Default Need help with trouble codes
Within the last week my car has been acting up. Last week i started up my car and it surged once and died. Started it back up and it ran fine but got a cel. Got the code scanned and it was my maf. Cleaned it and ran fine. today after getting gas i started it up and it ran for a few seconds and died again but no cel. Drove it an hour with no problems. Parked it for about 10 miniuts. Started it up to go get the new maf. I got to the end of the street and it died again. started it back up with no cel. Got the new maf and installed it. Started the car and it ran for bout 10 seconds and started to idle funny with the rpms dropping. Reved the motor and it stopped but got a cel. scanned the codes and got p0102 p0103 p0108. searched the codes and possiable fix for p0102 is a yelloe 20amp fuse blown in the engine bay fuse box. For the others got replace map sensor, check for vaccume leaks, o2 sensors (those should be tuned out because of headers). Any other input???
Old 09-11-2013, 06:25 PM
shamless self bump
Old 09-16-2013, 09:48 AM
The Scammer Hammer
dr_whigham's Avatar
There are 3 wires that go into the MAP sensor on the back of the intake. When this happened to me, the green one was pulled out of the wiring harness pigtail portion. I bought a 12 dollar MAP sensor pigtail and soldered it in and my symptoms went away.
This was about a year ago. I had my own thread about it.
The Scammer Hammer
dr_whigham's Avatar
Old 09-16-2013, 11:29 PM
ill have to check it out. can i get to it with out removing the intake? it hasnt done it again, yet. think it happens after numerous restarts
Old 09-17-2013, 10:44 AM
The Scammer Hammer
dr_whigham's Avatar
Unfortunately, you'll prob have to pull the intake. If you're small and flexible, you might be able to pull the map out and pull it out far enough to inspect the pigtail
Old 09-17-2013, 05:09 PM
thats the sensor at the back of the intake right?
Old 09-17-2013, 07:56 PM
The Scammer Hammer
dr_whigham's Avatar
That's correct
Quick Reply: Need help with trouble codes
