12 bolt axle stud options?
the available options are:
12mm x 1 1/2 (.505" knurl)
12mm X 2 1/2 (.505" knurl)
1/2" x 20 x 1 1/2" (.620" knurl)
1/2" X 20 x 3" (.620" knurl)
1/2" X 20 X 2" (screw in)
1/2 X 20 X 3" (screw in)
which should be ordered for stock axle lengths and stock brakes
what is the differences between them all.
LS1Tech Sponsor
Received 1,121 Likes
If you are using stock axles and brakes, the stock replacement wheel studs would be a 12 x 1.5 mm, with 0.505" knurl, and 1.50" long.
The other options you listed would only be used if you either want to change the thread size, or need an extended wheel stud for racing or wheel spacers. Hope this helps.
