new member 04 gto help!!
hello, my names cory I decided to join up on here to get some tips and help with my 04 gto. the car is almost at 100k and has long tubes and full exhaust. the car has been having system to lean bank 1&2 codes. cant figure that out and also when I start it in the message board it says service vehicle soon. run the code and it says engine oil pressure sensor switch low circuite. any help on these problems will be greatly appreciated.
also car is gonna be getting a tci stall and tsp 228 r cam this winter along with a professional products intake. only things left to buy are valve spring kit and a oil pump.
anyone have there things?
also what do you guys recommend for trans fluid with a 3500 stall?
do you guys recommend changing the timing chain and gear when upgrading a cam?
thanks cory,
thanks cory,
