WTT-98 Trans am M6 for A4 Trans am
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $6000
Mileage: 170000
Private or Dealer Listing: Private Listing
Location (State): AR
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Here is some info about my car. I bought it in June of 2010. The owner said it had a new LS7 clutch installed. I bought it with around 150,000 miles on it and it now has around 170,000 on it. Everything works in the car. Blows cold A/C. Headlights go up and down correctly. Now for the mods and work I have done since I bought it.
Poly motor mounts
MSD 8.5mm wires
SLP Lid
P&P Throttle Body
Borla Catback exhaust
Cutout for exhaust
BBK LT headers
Mail Order tune from Frost
Bosch 13111 Corvette 02 sensors
New brake pads and rotors all around
Founders LCA
Sakiou Micchi dual catch can
Swaybar bushings front and rear.A-arm bushing front, ball joints, tie rod ends, fuel filter
Always changed oil, trans fluid, and rear diff fluid.
C5 wheels from OEwheels 17x9.5". Nitto 555 tires on rear and Nexxen on front. All four have maybe 5000 miles on them or less.
Cons: Air Idle Control valve needs to be replaced. I just unplugged and it runs fine and A/C runs fine without it. I think the computer just compensates so I am not really even sure what the purpose of the sensor is. Drivers seats torn, dash cracked. The paint on the front half of the car is faded. I use a spray wax on it and you can't tell its fading.
