8s or bust!
8s or bust!
Fixing the glide this week, going to a 1.69 first gear set to hopefully get the power down, also putting some 3.90s in the car and hopefully will be able to make a full 1/4 mile pass. It went 5.82@117 easy on the 200 shot with a 1.30 60 so it should be good for bottom 9s if I can run it out the back door. It better get 8s on this setup because this winter it's getting a blow through with a x275 88 on e85 then we will see how fast this 6.0 can really go
Nice.. I also went 5.82 last weekend @ 120 tryin to get a 5.7 this week I'm going to play with timeing a bit and see what happens.. Care to share notes? I went to a 355 gear with a glide from a 410, I couldn't get it to hook. I still have a little tire shake now. What is your 330? I have never had your 60, my best is 1.33.. Keep us posted.
Went a 3.74 330, the next pass on the 250 jets it went a 1.27 60 on the back tires and then go out of it somewhere around the 330 but still went 3.68
In-Zane Moderator
Searching for a anti roll bar and I'll see where I can get the 80 coupe on a 150, I'll get some 175 jets but that's as far as these sniper kit is gonna go. I'll try to go after the area you guys are at, but not sure how much weight I can still cut with retaining all seats and dash. I have seen cars go from a 7.2 on motor and then 5.8-5.9 on a 175, but that was less weight in the same fox platform. I'm hoping the anti roll will help on motor alone eliminating water energy on squaring the RR, I'm sure 1.3x will happen on the gas.
So, I wish you guys luck and I'll see if I can get where y'all are now! I just don't see a 5.9 from a 6.9 on just a 150 shot but imma give her hell. The new glass hood will help a touch and I am still going to pull the AC blower box.
Old School Heavy
Are you getting the weld-in or bolt-on? I am going to get the HR Parts N Stuff bolt-in. Most guys on The Bullet like TRZ weld-in. The weld-in is cheaper and lighter than the bolt-on deals.
My car has all seats, dash, glass, etc.. I run consistent 6.40 on motor, I can't see going from low 7s to a high 5 but I've been wrong before.. 3020 with me in it.
Zones. I have UPR single adjustable lower control arms with the stock GT anti roll bar and air bags. I have not had to add air in the bags with the bar set-up and only have minor twist. I also have through the floor connectors and a 8 point cage so its pretty rigid.
In-Zane Moderator
