Turbo PCV system?
Old 09-12-2013, 09:16 PM
Black Reign's Avatar
Default Turbo PCV system?
Hello, What is everybody doing for there PCV system when adding a turbocharger or two? Right now I am venting to atmosphere on the passenger side and intake hooked to the driver side valve cover. Been thinking of either adding one way valves on both covers or venting both, possibly add ls6 valley cover if I go with one ways, building my 408 when I get home just want some opinions. Car will be a weekend driver that will mostly get challenged when its out, also plan on changing oil often, just don't need synthetic ruining my octane.
Old 09-12-2013, 09:41 PM
VIPERSLYR's Avatar
I have a jazz catch can that has a breather on the top. I ran -10 line from drivers side valve cover to can and -10 line from top of oil fill cap to catch can. Then have a Norris catch can with a line from ls6 valley cover to can and line from intake with a one way check valve so it does not pressurize motor. This set up works well
Old 09-12-2013, 09:44 PM
Moter's Avatar
Look up mightymouse on here. He makes some really nice ones that work well
Old 09-12-2013, 10:45 PM
Any pictures or diagrams?
Old 09-12-2013, 10:59 PM
Boneyard buick's Avatar
Also interested in this. I read that Denmah was venting his to atmosphere on his fairmont? Maybe he will chime in
Old 09-13-2013, 01:14 AM
5.3LStang's Avatar
I ran 1/2" hose from each valve cover to a Ebay catch can, works really good for me and only cost about $25
Old 09-13-2013, 04:25 AM
97WS6SCharged's Avatar
I'm running one of Mightymouse's catch cans on my 98. No turbos yet but it's a nice piece.
Boosted can with a one way valve built into the top fitting running to the intake manifold and a relief valve at the top of the can.
I put a fitting into the oil cap for the fresh air supply and ran the two fittings on the valve covers to the can.
Old 09-13-2013, 04:51 AM
samdogmx's Avatar
-10 in each valve cover to a vented catch can from jegs
Old 09-13-2013, 05:03 AM
VIPERSLYR's Avatar
You can see my set up in the thread project just 1000 rwhp is alive
Old 09-13-2013, 08:08 AM
Jefro6996's Avatar
I went with the mightymouse catch as well. -8 fittings on each valve cover to the can.
Old 09-15-2013, 12:20 PM
MIGHTYMOUSE's Avatar
you guys need to submit some pix to the customer page!
http://mightym0use.wix.com/mm-soluti...s-corner/c15xx
Quick Reply: Turbo PCV system?
