Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
5.3 build choices,
Old 09-15-2013, 06:49 PM
bears416's Avatar
Default 5.3 build choices,
Doin a 5.3 carb into a s10, bought the kit with the edlbrock box and vic ir, I no the box isnt the best and its still in the build stages so I dont wanna get rid of it.
Question 1 will this box work wth like a 100 shot of nos
2 will my vac secondary carb be ok with nos,
3 and will a stock tbi fuel pump regulated to 5 or 6 lbs hamdle the 5.3 and a 100 shot
Old 09-15-2013, 09:08 PM
bears416's Avatar
Does any body know what the 2 plug holes are for on my th350, not the 2 for the lines but its the ones farther down. Im sure ones for the dipstick idk about the other
Old 09-15-2013, 10:39 PM
In-Zane Moderator
ZONES89RS's Avatar
That eddy box is junk for nitrous, period.
No.
Your vac sec carb will work on the dope.
The TBI system will work for the motor but i would run a separate dedicated fuel cell and pump for the nitrous, well worth it to make sure your engine does not blow.
The trans has a dipstick tube hole and a kick down cable hole.
Old 09-15-2013, 10:43 PM
bears416's Avatar
Ok, its fully manual valve body, so plug 1 hole thats not the dipstick, plug vaccum module and run it like that?
Old 09-15-2013, 10:48 PM
In-Zane Moderator
ZONES89RS's Avatar
If someone built it into a MV body then they should have already plugged those locations. So, if they are not, you will need to block them off.
Old 09-15-2013, 11:00 PM
bears416's Avatar
Its newly built not been ran, what shud I plug em with
Old 09-15-2013, 11:32 PM
In-Zane Moderator
ZONES89RS's Avatar
A chopped off detent cable mount for that and make a plug for the vac ac valve.
Quick Reply: 5.3 build choices,
