Possible Spark blow out at 25psi w/LS1 coils
Im running the BS3 on my supra with the LS1 coils. Last year i ran 30psi with a .028-.030 gap on the plugs with no issues. Changed over to a mechanical pump and 240lb injectors. Took the car out recently and it starts breaking up around 20psi. Thinking it was just plugs i pulled them put new in. Took the car out again same results. I was going to run more boost and bring the gap down but want to figure out what happen here. How can i check for a weak coil?
Thanks for the replies. What would u recommend for dwell time? After everything is working I plan on running upwards of 40psi. Thoughts on plug gap with 45psi?
"Im running the BS3 on my supra with the LS1 coils. Last year i ran 30psi with a .028-.030 gap on the plugs with no issues."
"Changed over to a mechanical pump and 240lb injectors. Took the car out recently and it starts breaking up around 20psi."
I would look at the change you made and start there.
