LS3 or TFS235 Heads?
Old 09-17-2013, 02:27 PM
ss performance's Avatar
Default LS3 or TFS235 Heads?
I am building a 408 for Twin turbo's I have stock LS3 heads and TFS 235's.
I have a FAST 102 for the TFS heads or a stock LS3 intake for the LS3 heads.
Which head do you thing would be better?
I'm leaning toward the LS3 heads, that way I can sell the TFS to help pay for the build but I don't want to compromise the potential of the build to save a few bucks.
Any input would be helpful.
Thanks
Old 09-17-2013, 03:42 PM
Gabbiani's Avatar
What are the goals?
Old 09-17-2013, 03:51 PM
Rise of the Phoenix's Avatar
I would go with the LS3's and sell the TFS heads. Those LS3 heads are going to be plenty for a twin turbo 408.
Old 09-17-2013, 04:14 PM
TT427's Avatar
I would use the tfs, thicker deck and better exhaust port... Though chamber size may sway me to the ls3 if they are bigger especially with those cubes. Maybe another issue, not sure how important, but ls3 work on that bore but not ideal, the tfs are setup for that bore or am I mistaken? Take into account springs and lobes you will be using. The tfs might save some aggravation...
Old 09-17-2013, 08:34 PM
Reducing aggravation is always a plus.
I'm shooting for 800-1000 whp. I'm thinking about removing the A/C & power steering. Swapping in a 4L80. Currently have a M9 with 3.89 gears on a Wavetrac carrier 35 spline axels.
I'm leaning towards the LS3 heads because I can sell off the TFS 235's and FAST 102 intake to help finance the turbo setup.
Old 09-18-2013, 04:46 AM
THADD's Avatar
TFS and sell the LS3 stuff
Old 09-18-2013, 07:11 AM
BLWN1's Avatar
How much on tfs setup?
Old 09-18-2013, 07:18 AM
LS1Tech Sponsor
hellbents10's Avatar
Stick with the TFS if you do not move water at high HP levels. We ran them to 1800hp, they will hold all day with MLS gaskets under 1500.
Old 09-18-2013, 07:25 AM
Cam72aro's Avatar
Good info from a very knowledgable source. I would do the tfs since its obvious you want to make some power. Less chance of pushing water at high boost levels.
Old 09-18-2013, 03:06 PM
thank
I appreciate all the feedback.
Old 09-18-2013, 03:30 PM
Detoxx03's Avatar
Keep the TFS heads. As hellbent advised you want to avoid lifting the heads and pushing water.
Old 09-18-2013, 03:35 PM
DEFYANT's Avatar
I would keep the TFS heads, and send them to Tooley for some fine massaging.
Old 09-18-2013, 04:54 PM
That's the way I'm leaning now. Who is Tooley and how do I contact him?
Thanks
Old 09-18-2013, 05:30 PM
TT427's Avatar
I would search the comparison, I remember seeing a few discussions and the general trend was the 235/102 was worth power and torque over the LS3. I wouldnt put money into them, but if the springs are sufficient for your intended cam, the better exhaust port, better deck and better for that bore it would be the head to use. I would think these will make more power or same power at less boost as is.
Old 09-18-2013, 09:46 PM
DEFYANT's Avatar
Brain Tooley of Brian Tooley Racing, http://www.briantooleyracing.com/.
Quick Reply: LS3 or TFS235 Heads?
