spark plugs for boost?
tr6 for a low boost setup
br7ef is a colder plug i would use for a more wild setup, honestly i dont have an issue with either, i run pumpgas and washer fluid with high alcohol content as methanol
Easier to foul, harder starts, misfires at low load/rpm.
TR6s worked fine at 800rwhp in my car. Now running BR7EFs at ~1000rwhp. Got a set of TR7IX to swap in once I stop being lazy.
you only have those problems if your fueling is not correct.....
I've been on 9's and 10's for several years with my nitrous setup, and never had any issues with Fouling, Hard starts or misfires
plugs are clean at idle, and clean at WOT. (you dont need as much fuel as a lot of people think you need)
also, get rid of that irridium crap....makes it darn near impossible to read plugs to get fueling correct.....
also, you want a Non Protruded tip resistor plug.....less chance of a hot spot to cause detonation and less EMI interference issues that can cause misfires.
I don't think there's an issue running a colder plug. Only reason I have 7s in is because I have an a2w and sub ambient IATs. Some would call 7s in my case overkill. lol
I ran BR7's during tuning, was running good until it started cutting out, (fouled plug I guess) I went to a TR6 , ran VERY good .
I am at 13 psi with 11.6 A/F 15 degrees timing WOT.
I want to go TR7IX Soon just to be safer and to go iridium.
FWIW I don't think they make an actual TR7 plug like a TR6, anything TR7 or TR8 will be iridium tr7IX or tr8IX IX being iridium and more expensive, if there is a regular tr7 or 8 let me know the part number I could never find one
