ARP Pressure Plate Bolt Torque Spec
Old 09-18-2013, 05:46 PM
badazz81z28's Avatar
Default ARP Pressure Plate Bolt Torque Spec
Anyone know this? I know what stock it, but this part # doesnt register on the website.
Thanks
Old 09-18-2013, 11:02 PM
themealonwheels's Avatar
From previous experience, its more than 74ft-lbs with moly lube. I installed to the gm spec 74ft-lbs and had to pull my tranny to retighten when unexpected vibes from the tranny mount caused my bolts to back out.
if you're using arp assembly lube on arp bolts, 84ft-lbs. If using arp bolts with red loctite, 74ft-lbs is my guess.
Old 09-19-2013, 07:55 AM
slt200mph's Avatar
Here is ARP's phone number. They will be happy to answer your questions. There is no need to guess.
800-826-3045
Old 09-19-2013, 04:36 PM
Dang, not even close, PP bolts are in the hood of 45 to 52ftlbs.
Anyone wonder how you get an accurate torque with the plate load pushing against the head of the bolt? Seems one you have the plate bolted down to were its flush, the torque wrench will click without any additional rotation.
Old 09-19-2013, 08:17 PM
S10xGN's Avatar
Hope you are tightening them all a turn at a time and pulling it down evenly. I pull them all like this, torque each bolt in 3 stages to the final value, then go around several times at final value to make sure nothing moves. As a side note, once all bolts are down, pick one and you can remove it (almost) by hand as the others hold the plate down.
Old 09-19-2013, 10:05 PM
Hmmm....I wish I had that idea last night. Its already back together
I cris-crossed the tightening sequence, and went around the wheel ensuring they were torqued to 52, but they already seemed to be about that tight already....
Old 09-20-2013, 09:27 AM
I have been installing clutches for years and just now I realized that....But I guess if the pressure of the PP is pushing back, I assume the bolts are stretching to ensure clamping force? I don't think anyone really has dug this deep into it...
Old 09-21-2013, 04:52 AM
Oh dang, good you corrected me. Not sure why I had flywheel to crank bolts in mind, he clearly said pressure plate!
Quick Reply: ARP Pressure Plate Bolt Torque Spec
