Pontiac GTO 2004-2006 The Modern Goat
416 LQ9 Stroker build 04 QSM
Old 09-18-2013, 06:25 PM
Cwarta's Avatar
Default 416 LQ9 Stroker build 04 QSM
Hey guys, giving my 04 a stroker finally.
Looking for well over 500rwhp, but its gunna need some head changes im sure.
Fresh LQ9 block
Callies 4" crank
Eagle 4340Hbeams
Manley Platinum series flattops
King XP bearings
Akerly and CHilds rings, plasma moly top ring and Napier second
Custom FTI cam
Vic JR intake and 92mm TB
Hand Ported LS6 243`s - Decked .010, 5 angle valve job, bowl work, etc.
trunion upgrade
1 3/4 headers - Catless mids and Borla XR1 muffs all 3" true dual
25% UDP
Mcleod RST twin disk
1 piece PST 3.5 aluminum DS
3:91`s
Pro Stars (SHaved 64# off old tires/wheels)
42# injectors
On E85 when new pump and injectors arrive
CAnt wait
Old 09-18-2013, 07:24 PM
HCI2000SS's Avatar
Sounds like a very stout setup!
Old 09-18-2013, 08:44 PM
Cwarta's Avatar
Im sure hoping so
Old 09-19-2013, 09:00 AM
Raoul-Duke's Avatar
Sweeeeet.
Old 09-19-2013, 04:41 PM
Cwarta's Avatar
Thanks guys!!
New eagle 6.125 rods 7/16 arp 2000's
Old 09-20-2013, 02:21 AM
Canada's Avatar
Interesting last I checked a LQ9 could only be bored out to a 408. Going to need better heads and intake and open up that exhaust more. Lot of people skimp on the top end. Why didn't you go with a steel top ring? Rough cam specs? I love my 408 Lq9. What pistons? What kind of lifters you go for? Whats yoru compression? I really dont see that motor hitting 500rwhp and going to take some serious money put into the heads and rockers to help get you close to or over 500. Good luck with it, just hope you have some suspension to get the new power to hook or its just wasted.
Old 09-21-2013, 06:10 PM
Cwarta's Avatar
I have lunati link bars, I don't even know the cam specs yet but I know Ed will do what he does best, and like I said I know the heads are going to be a big restriction, along with the headers. Compression is 11.9:1, and i have a set of cnc ported ls3 heads thst im having fixed thst will find there way on here. and as far as suspension, it has 1pc DS, 2 way adjustable coil overs rear, koni 90/10 race struts up front, and full time DR. 3:91 geared
Old 09-21-2013, 06:52 PM
Blackpanther99's Avatar
Very stout build list Should be a nice goat turned into a beast.
Old 09-21-2013, 08:57 PM
Cwarta's Avatar
Thanks man I can't wait!
Old 09-22-2013, 08:01 PM
Cwarta's Avatar
Picked this up to top off the Vic Jr
Old 09-26-2013, 06:50 PM
Canada's Avatar
So are you using a stroke ls3 block or is it a 408? LS3 heads I personally dont think show any advantage unless you go boosted. I'm a cathedral fan, just get some good aftermarket ones and good to go. If your staying n/a I'd mill the heads and bump the compression up since your only 11.9:1 You can go up into high 12s and low 13's and stay on pump gas.
Old 09-26-2013, 09:33 PM
Cwarta's Avatar
I'm using an lq9 block bored to 4.065 and a 4" stoke dragons layer crank.
I'll be doing more research on the heads setup etc.
Cwarta's Avatar
This sexy piece of aluminum is going to top off the 416! Hope to pick up the block and start assembling tomorrow!
And my DW265lph pump from Kollar
Old 09-26-2013, 09:45 PM
Rise of the Phoenix's Avatar
What made you decide on the Vic Jr over the Super Vic? Also, are just upgrading the pump and running stock lines?
Old 09-26-2013, 10:50 PM
Cwarta's Avatar
I purchased the vic jr when I was planning on a forged 6.0, and now I have a little bigger engine. When I decide what I want to do with the heads ill make an intake decision as well! And yes just a pump upgrade same lines
Old 09-27-2013, 08:35 AM
I'm looking forward to seeing this build come to fruition. I hope you Re able to meet and exceed your power levels.
Old 09-27-2013, 11:50 AM
Cwarta's Avatar
Thanks! I'm really hopping to pick up the engine today from the machine shop so I can assemble it! I really want this thing back on the road, it's been down since march :/
Old 09-27-2013, 12:47 PM
The longer the wait, the more you'll enjoy it once it's all finished.
By the way, is the cam Ed grinding you spec'd out for cathedral style or LS3 square port heads? I know you have the cathedrals now, but I thought I read you plan on possibly going with square port.
Old 09-27-2013, 01:32 PM
Cwarta's Avatar
Yes I do, and ill have a new cam done for em!
Old 09-29-2013, 12:36 AM
Cwarta's Avatar
Block is machined, cam bearings installed, cleaned and painted ready for assembly tomorrow
RIngs are file fitted and sorted per cylinder.
Quick Reply: 416 LQ9 Stroker build 04 QSM
