How do i know if my asp pulley is on all the way with my roller master double chain ?
Old 05-03-2004, 08:19 PM
1Fst98ta's Avatar
Default How do i know if my asp pulley is on all the way with my roller master double chain ?
I did the instrutions on ls1howto and i am unsure if my crank pulley is on all the way ... the belts arent flying off and they look like they are aligned however the end of the crank isnt all the way to the end of the inside of the pulley .... so how do i know if it is on all the way ?
Old 05-03-2004, 09:01 PM
felton316's Avatar
Did you you seat it with 230 ft-lbs of pressure?
Old 05-03-2004, 09:08 PM
1Fst98ta's Avatar
Cranked it to 240ft lbs took the old bolt out then put the new in ... then 30 some foot lbs and another 140 degrees
