4l80e complete swap kit for big power
Category: Drivetrain
Price: $2500
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): MD
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
The trans has a trans go stage 3 full manual shift kit so its a full manual valve body. (you HAVE to shift yourself) I have all the stock parts should you want to convert back to full auto. The converter is a Percision Industries nitrous converter with multi-disk lock up. It does not stall high on motor but its a must on the nitrous. It will come with everything needed to swap into any GM V8 vehicle minus the cross member and drive shaft.
Included is Trans, converter, harness, shifter, and cable. I can also include a custom cross member and driveshaft for a fox body swap.
I drive to the track and back home. This trans is tough.
If you would like to test the trans out while it's still in the car feel free! Absolutely nothing wrong with it. Just made some passes this weekend in the MD Top ten race at 75&80.
Looking to go full race and I want to try a glide
Located at my shop in Damascus MD 20872.
What is the rated stall on the converter and are you at all interested in selling separately? I'm assuming the converter would lock up normally assuming you didn't have a full manual trans, correct?
Thanks,
Dave
Thanks,
Dave
