Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
550hp Mast Motorsports 6.8L stroker 416 LS3
Old 09-21-2013, 08:31 PM
man-o-war's Avatar
Default 550hp Mast Motorsports 6.8L stroker 416 LS3
Category: Engine - Complete Motors
Price: $7500
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, Small Block
LS Engine?: Fits LS Engine
Up for sale is my Mast Motorsports Cyclone 550hp stroker.
www.mastmotorsports.com
6.8L, 416ci, EFI, VVT, DBW, all forged internally, all aluminum motor
This came off my airboat, with only 374 hours of use. Motor is 2011, serial number 1114. Sold the aluminum airboat hull, kept the motor. My shop opened the motor, checked everything, and installed new Clevite 77 bearings (main and rod) while we were in there. They just finished it this week. Motor is complete and in perfect condition with perfect compression and no use since, except for the bench start seen in the short video. Reliable drive-by-wire setup, ready to install.
Full list of parts:
Type: L92 6.8L Aluminum
Displacement: 416 Cubic Inches
Compression: 11:1
Bore x Stroke: 4.070 x 4.000
Rev Limit: 6,200 RPM
Crank: Callies Forged
Rods: Callies Forged H-Beam
Pistons: Mahle Motorsports
Cam: Mast L92 Core Custom VVT Cam
Heads: LS3/L92
Intake: L92 Truck
Valve Springs: Mast Nitrided Beehive
Not Included: Engine Headers
Fuel required: Premium 91-93
Cyclone Specs & Equipment:
GMPP LS3/L92 6.2L Aluminum Block stroked to 6.8L, Finish Bore 4.070” & Finish Decked 9.230”, Mast M-90 ECM and Wiring Harness with Fuse Block, GM Foot Pedal & Starter, Bosch UEGO O2 sensors, Crankshaft & Camshaft Position Sensor, Oil Pressure & Engine Coolant Temperature Sensor, Engine Knock Manifold Air Pressure & Intake Air Temp. Sensors, Ignition Coils, NGK 4091 Spark Plugs & Mast Plug Wires, L92 Truck IAFM, LS2 Bosch Fuel Injectors & Dead Headed Fuel Rail, 87MM Throttle Body & 8-Layer K&N Air Filter w/IAT Bung, Callies Forged Crank & Forged H-Beam Rods, Clevite 77 Rod & Main Bearings, Mahle Forged and Coated Pistons, Mast Phaser VVT Cam & Mast Premium Nitrided Valve Springs, Felpro Head Gaskets, ARP Head Bolts throughout, L92 Cylinder Heads, LS3 Stainless Steel Intake & Inconel Exhaust Valves, L92 Water Pump & L92 Truck Oil Pan, Mast Pushrods, Melling Oil Pump, Wix Oil Filter, AC Delco Alternator, Extreme Duty Flywheel, Walbro 255 L/hr Fuel Pump GSL392, GM Corvette Filter/Regulator & Fuel Fittings, Catch Can, Canton Oil Cooler Sandwich Adapter (included, not installed).
New parts include:
K&N filter
IAT sensor
Valvoline VR1 oil
NGK R spark plugs
Mast spark plug wires
Walbro GLS392 high pressure fuel pump
GM fuel pressure regulator / filter
M90 ECM USB cable for diagnostics/calibration/tuning on any laptop
Video of the engine startup on the bench:
http://vid45.photobucket.com/albums/...pse6996dc7.mp4
This motor is a beast, get it for half price
You can reach me via PM
Motor is located in Palm Beach Florida 33470
man-o-war
Attached Thumbnails 550hp Mast Motorsports 6.8L stroker 416 LS3-mast-l99-001-lg.jpg   550hp Mast Motorsports 6.8L stroker 416 LS3-20130910_153446_zps1f91d59b.jpg   550hp Mast Motorsports 6.8L stroker 416 LS3-20130910_153514_zps6c35fc09.jpg   550hp Mast Motorsports 6.8L stroker 416 LS3-cyclone-specs.jpg   550hp Mast Motorsports 6.8L stroker 416 LS3-cyclone-dyno.jpg
550hp Mast Motorsports 6.8L stroker 416 LS3-20130912_132357_zps9a42a254.jpg   550hp Mast Motorsports 6.8L stroker 416 LS3-20130919_163205_zpsf6923229.jpg
Old 09-29-2013, 10:06 AM
man-o-war's Avatar
Sold tnx
Quick Reply: 550hp Mast Motorsports 6.8L stroker 416 LS3
