Need Help Using Edit To Lock Converter On Dyno
Set the TCC lock to 2 mph higher than the 3rd gear shift point for all TCC tables (exculding those not used.....ie 255 for all of the values). This will lock the TCC once the car shifts to third. Just make sure that you put the auto in nuetral once you get off the gas.
-Kevin
-Kevin
-Kevin
-Kevin
what if it still doesnt lock up?
