ls1 meziere water pump electric blue drag ls1-ls8 $375
Category: Accessories
Price: $375
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NY
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Meziere Electric Water Pump - LS1 thru LS8
Show Picture 1Show Picture 2Show Picture 3Show Picture 4Show Picture 5
Meziere LS1-LS8 Electric Race Water Pump (35 GPM)
item# MEZWP119
Share on emailShare on printMore Sharing ServicesShare
Previous Up Next"
Item for part numbers: WP119S (black); WP119R (red); WP119U (polished); WP119B (blue); or WP119C (chrome).
Meziere, one of the only companies to offer a 2 year, unlimited mileage guarantee and full satisfaction money back guarantee. This should convince you that buying Meziere is buying value!
This water pump model features:
Fits GM LS-1 through LS-9 engines
Suitable for street or drag strip use – 2500+ hour life expectancy
Show quality red anodized finish
Standard motor provides 35 gallons per minute free flow rating
All stainless steel hardware included
Light weight. Complete standard GM LS-X unit weighs only 7.0 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal
Pump will clear cam belt drives and most blower drives
1" NPT inlet adapters are available for #12AN, #16AN, #20AN, 1¼", 1½" or 1¾" slip hose
1" NPT to 1 1/4" hose outlet adapter included
Technical Specifications:
Belt Drives: Standard LS-X design will clear Jessel belt drives and comparable belt drive systems.
Distributer Belt Drives: Spacers will be necessary to clear belt drive distributor systems.
Finishing The System: This pump is supplied complete with gaskets and hardware but without the inlet fitting. The fitting needs to be ordered according to the size of the lower radiator hose.
Amperage draw: Under normal use the pump will draw 6-7 amps.
Overall Height Dimension: The standard pump is 6.80" long from the mounting surface to the tip of the pump.
Pump Weight: This application weighs 7.0 lbs.
16 volt systems: When purchasing a pump for a 16 volt system we recommend the 16 volt optional motor on our pump. The 12 volt pump will work for limited use applications.
Additional Notes:
The standard 35 GPM pump is suitable for normally aspirated engines up to 650HP. Supercharged, turbocharged and high compression, high horsepower applications should use the 55GPM High Flow pump only. This model does not accept heater or bypass hoses as a standard. These may be added at the factory for an additional cost. Please call for details.
